Can a newer verson of FFMPEG be used with SVCD2DVD?
I'm trying to convert BD-9 to DVD-9. Using tsMuxeR to create .ts file from .m2ts
Using the latest version of SVCD2DVD I have problems with FFMPEG failing
This happens with 2-pass and may also be related to high bitrate.
It does work with 1-pass.
So can a newer version of FFMPEG be used since the one in the SVCD2DVD package is from 2008?
Or is an update to SVCD2DVD coming soon. Would also be great if it could read m2ts files directly.
Results 1 to 11 of 11
It's a known issue and has so far been determined that there is no visible difference between 1 and 2 pass. Just stick to 1 pass.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I will get this sorted after the weekend (i will be away). I will PM you a new build to try.
Just checking to see if you've had time to look into this yet or if you're made progress with it!
Thanks -
I have a new build to test.... Drop me an email and you can have a play....
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum CapturingReplies: 1Last Post: 14th Feb 2012, 04:11 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 09:00 -
Older FFmpeg encodes MUCH Faster than newer builds!?
By V1de0Luvr in forum Video ConversionReplies: 4Last Post: 25th Nov 2009, 07:33 -
ffmpeg failure when using svcd2dvd
By cathalcelia in forum SVCD2DVD & VOB2MPGReplies: 26Last Post: 11th Oct 2007, 20:10 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
