So quality loss is neglible; I thought for some reason there were quality issues. If there are negligible quality issues, then there is no reason to adjust the bitrate
You said the "encoded file is different" which prevents you from making a patch. It's supposed to be different (at least when you add translations).
Is there some CRC check in the game that prevents you from using parts or whole of the 2nd file?
Can you swap out one entire video with a re-encoded one, and does it work/play ?
Results 31 to 34 of 34
What I meant with "different" is the fact that after making it, I grab a patch maker and compare both videos, the resulting patch is very big (if the video is 30 MB the patch is 20 MB), which will make a huge patch once I have all the videos ready.
The subtitled version, regardless of how different is from the original video, works just fine within the game, so I know the codec I'm using is right. -
Did you test that big patch, and it works? So the problem is the huge filesize?
Is that uncompressed or compressed patch?
You will find older, poor compression codecs respond very well to compression (so if you distribute your patch compressed with winrar or zip for example). For example, I downloaded a sample DUCK video from that link earlier, and winrar with normal compression settings compressed it to <50% of original size -
Sorry for the delay. The patch-making software also compress the files. Still I've tried to compress it using 7z and it didn't made a difference.
What's the best tool to cut/trip MKV videos?
By creamsoda in forum EditingReplies: 16Last Post: 4th Jan 2019, 16:36 -
Hexadecimal header and offset of a MPEG-2 Transport stream file?
By coconut83 in forum ComputerReplies: 1Last Post: 26th Oct 2010, 11:41 -
Videos converted skip and are cut off
By gdreger in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 28th Dec 2009, 16:12 -
Why do videos converted from FLV not behave nice in editors?
By resonatored in forum Newbie / General discussionsReplies: 5Last Post: 26th Apr 2009, 19:03 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 16:55
