Hello guys,
does anyone know how to make readable srt Cyrillic subtitles on Panasonic DMR-BS750 from USB flash memory DIV X,AVI format movie?
Thank you
This is a good question, but you're probably not going to like the answer.
First of all, you have to find out if the Panasonic supports Cyrillic or not. The manual should tell. Note that typically DVD players have a rather reduced character set that they'll support for Divx subtitles. You'll get Latin and maybe if you are lucky Cyrillic. But I've heard of support only for Latin characters and for Latin plus something other than Cyrillic.
Assuming your Panasonic does support Cyrillic, you have to find out WHICH Cyrillic it supports. Usually it's CP-1251. Unicode is almost never supported. If the player supports some Cyrillic format like KOI8_R or ISO-8859-5 (I actually have a Philips DVD player that supports this incredibly obscure and ancient Cyrillic encoding) you will have to change the Cyrillic to this format. Good luck. Oh - you will need to do any encoding changes on a Windows box or you'll probably have issues with the player not understanding it if you do it under Linux or OS X.
How to see subtitles with Panasonic DMR-EH57
By gudboi in forum SubtitleReplies: 0Last Post: 9th Jan 2010, 16:28 -
Copying DivX to HDD on a Panasonic DMR-EH57
By Ouchies in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 07:05 -
How can I add my subtitles in Cyrillic to a movie?
By Misterygirl in forum SubtitleReplies: 19Last Post: 17th Jul 2008, 14:51 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 15:05 -
Panasonic DMR-EH56 doesn't play 2nd audiotrack of DIVX-file
By Scotty73 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2007, 12:27
