Greetings! I'm new in all related to dvd/blu-ray authoring, and i have been strugling with something related to subtitles.
I have a video whose resolution is 720 x 480, and i have a ssa subtitle file. I use convertxtodvd 4. in the resulting dvd the subtitles appear very low in the image, you can only see upper half of the text. i tried to fix the resolution of the ssa file with aegisub, but the result is always the same. so i changed the position of the first line, also with aegisub, to {\pos(360,440)}, but i could not find the way to change all the 1500 lines automatically to the same position. could anyone help me with this?
THANKS IN ADVANCE!
	It might be easier to use DVDSubEdit on the files ConvertXtoDVD produced, or look at the subtitle position features in ConvertXtoDVD itself. Read my blog here.
	SSA files are plain text.
 Open with a text editor and do a search-and-replace (or maybe Aegisub supports this).
 Or you can use DVDsubedit to adjust positions in a VOB set. Change one then
 "Edit/Apply last modification to all", and save
	Thanks guns1inger and AlanHK! Problem solved! Now I have another problem, ConvertXtoDVD sometimes does not recognize italic tags in some lines of the .ass file, and in the end of it appears, for ejample: ¡Jenny! ¡Please go!{\i0}. I played my video file with the subtitles in VLC media player, and everything is perfect, but when it comes to the DVD, only some of the lines have this problem. Is there another software like ConvertXtoDVD for authoring dvd's with capacity to read .ass files with all the tags? Or a different software like Aegisub for editing .ass files, and adding tags like bold, italic, etc.?
  Change on-screen position of PGS (SUP) subtitlesBy YankeeFan in forum SubtitleReplies: 6Last Post: 21st Mar 2022, 11:43
  Subtitles in video : detect time positionBy Urban20 in forum SubtitleReplies: 2Last Post: 15th Nov 2011, 04:24
  FFmpegX Subtitles Position not workingBy kidart89 in forum ffmpegX general discussionReplies: 2Last Post: 8th Nov 2008, 21:02
  How to edit the position of subtitles for softsubs?By VidHunter in forum MacReplies: 0Last Post: 10th May 2008, 14:46
  Problems with Subtitles Position on screenBy impulse_16 in forum SubtitleReplies: 11Last Post: 27th Oct 2007, 11:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
