Results 1 to 12 of 12
    May 2010
    Australia
    I bought a new camera, EOS550D, and been filming video in 1920x1080. I imported to Final Cut. However when I export to QuickTime in 1920x1080 the video looks stretched? I tried using with aspect ratio (letterbox) and without and still doesn't work – it still looks stretched wide! any ideas?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Is the final cut project set to 1920x1080? Does the preview window show 16:9?
    What do you mean "stretched"? Can you show a sample frame?
    Give more details on your project and compressor settings.
    http://www.kiva.org/about
    May 2010
    Australia
    doh! you're right I didnt set FC to 1920x1080. Thanks so much for your help edDV
    May 2010
    Australia
    oops! spoke too soon - it still doesn't look right. See attached image. The one at the top is in FCE, the one at the bottom is in quicktime.
Name:	Screen shot 2010-05-27 at 11.41.39 AM.png
  5. Member edDV's Avatar
    Mar 2004
    Settings?
    I can't replicate this here. My FCP box is being rebuilt.
    It is a settings issue for project or Compressor. Or the source file is not flagged 16:9.
    May 2010
    Australia
    The footage is capture in 1920x1080, and I'm trying to export in 1920x1080. Its weird, with the previous two cameras I had there were no problems like this.
Name:	Screen shot 2010-05-27 at 12.07.36 PM.png
Name:	Screen shot 2010-05-27 at 12.09.19 PM.png
    May 2010
    Australia
    Ok, this is weird. I found that that I export in QT using 4:3 ratio it looks correct! How is this possible when the source video is 1920x1080?
  8. Member edDV's Avatar
    Mar 2004
    Somewhere in the source properties, project or movie settings.
    This thread should be moved to the Mac forum.
    May 2010
    Australia
    Thnks for your help - would you think its the FC settings?
  10. Member edDV's Avatar
    Mar 2004
    Without access to FCP
    First FCP is very fussy about import formats. The source must be properly flagged as 16:9 preferably in the AVCHD or Quicktime h.264 format (latest version only). The project setting must be 16:9 1920x1080. Frame rate must be set to 24p progressive.
    First clue is whether the preview pane shows what you want.
    Then focus on encoder settings.
    Four black borders normally result from 4:3 (assumed) video import to a 16:9 project. This results in pillarbox preview. If you haven't identified the source as 16:9, most edit software will assume 4:3.
    Then encoding this to 16:9 causes the pillarbox to be letterboxed. Result is four black borders.
  11. I'm a Super Moderator johns0's Avatar
    canada
    Thread moved to mac forum.
    May 2010
    Australia
    worked out what I did....I didn't set the sequence settings to 1920x1080 before bringing in the video from my HDD!!! Thanks again for your help edDV!
