Thanks for the suggestion, it makes sense and I tried it although
rendering in FFV1 took about 20 minutes and rendered an unplayable file.
Sure wish I could get at the root of the problem.
Here is the work flow.
1. Using XcConvert or Morgify - Resize 4:3 images to 16:9 1920/1080.
2. Using FFMPEG render png Images to HuffyUV in MKV container.
3. Using KDENLIVE - Edit MKV Clips into and renderable sequence.
4. Using KDENLIVE - Render to HuffyUV MKV.
What is mysterious is that
* consistently the effected sequences have the above glitch.
* consistently the non effected sequences do not have the above glitch.
* consistently in the frames that have the problem there is only 35-50 pixels wide effected.
Perhaps the root of the problem is in the source frames themselves but when I compare
both the Clip properties and image properties so far I see no differences at all.
Any speculations or suggestions appreciated.
Results 31 to 32 of 32
How do I install Huffyuv (mt)?
By blud in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2012, 07:47 -
HuffYUV Question.....
By vipin in forum Video ConversionReplies: 7Last Post: 7th May 2010, 13:36 -
H.264 to HuffYUV
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 4th Apr 2008, 01:25 -
is it possible to compress HUFFYUV?
By Lee82 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2007, 13:56 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
