first the info. i have two hard-drives, setup into three seperate partitions. one for windows only, second for appz/gamez. the third, the unpartioned hard-drive i use for video editing. now here's the problem. i'm running win98se, so i get huge problems from the stupid 4gb avi limit on fat32. what i want to know is, if i install winxp, can i have one hard drive (os/gamez/appz drive) as fat 32. while the other hard-drive (video editing) is ntfs, so i don't run into the 4 gb limit? if this is possible, then i will most definately upgrade to winxp proffesional shortly. thanks for any info anyone can offer.
TA69
Windows XP Pro will allow you to use the fat32 on one of your drives and the ntfs on the other. It will also allow you to mix the file systems on different partitions on each drive. In addition it will allow you to install more than one os on your drives. You may want to consider this if you have games that might not run on XP.
For instance keep one drive as fat32 with your present os (Win 98 or ME). The other drive (make this the primary drive and set as active) would have XP installed with ntfs and all your video editing would reside on this drive.
When Xp starts-up you will get a screen that asks you to select which os you want to use. You can set this to default to either os and you can set the time allowed to make your decision.
While it doesn't take a genius to figure out how to set this up in XP, it does take a little bit of reading and investigation. Check out the "help and support" section after installing XP. If you are on-line when you use the help and support section, XP will also include info that doesn't reside on the installation disk but is available from Microsoft. -
just make them all NTFS i think it manages data for effectly and i swear it freed up about 1 gig on my disk.
ok, thanks alot for the help everybody. the only reason i don't go with ntfs for all the drives is i have 30gb's of stuff, that would take just to many cd's to backup.
chips144, i'll most likely be doing that. you, or anyone else, doesn't happen to know where i could get an in-depth tutorial on how to do this?
TA69 -
Here is the basic info from Microsoft relative to multiple operating systems. I have also e-mailed you this info.
Installing more than one operating system on your computer
You can install more than one operating system on your computer and choose which operating system you want to use every time you start your computer. This is often called a dual-boot or multiple-boot configuration. Windows XP supports multiple booting with MS-DOS, Windows 3.1, Windows 95, Windows 98, Windows NT 3.51, Windows NT 4.0, and Windows 2000.
Disk volumes and disk format
Each operating system must be installed on a separate volume on your computer. In addition, you must ensure that the boot volume is formatted with the correct file system. You must reformat and repartition your hard drive if:
You have only one volume (so each installation can retain its own files and configuration information).
The boot volume is formatted with the NTFS file system.
If you want to install Windows 95 or Windows 98 with Windows NT 4.0 or Windows 2000, the boot volume must be formatted as FAT, not NTFS, because Windows 95 and Windows 98 must be installed on the boot volume when more than one operating system is installed, and FAT is the only file system those systems support. Windows 95 OSR2, Windows 98, Windows 2000, and Windows XP support FAT32 volumes.
However, if you format a Windows NT 4.0, Windows 2000, or Windows XP volume with any file system other than NTFS, you will lose all NTFS-specific features. This includes some Windows XP features such as file system security, encrypting file system (EFS) settings, disk quotas, and Remote Storage. Likewise, Windows 95 and Windows 98 cannot recognize an NTFS partition and will identify it as unknown. Therefore, if you format a Windows 98 partition as FAT, and a Windows XP partition as NTFS, any files on the NTFS partition will not be available or visible if you try to access them while running Windows 98.
Operating System Supported File System
MS-DOS FAT
Windows 3.1 FAT
Windows 95 FAT
Windows 95 OSR2 FAT, FAT32
Windows 98 FAT, FAT32
Windows 2000 FAT32, NTFS
Windows XP FAT32, NTFS
How to create a multiple-boot system with MS-DOS, Windows 95 or Windows 98, and Windows XP
You will be less likely to encounter problems installing a multiple-boot system with MS-DOS, Windows 95 or Windows 98, and Windows XP if you install these operating systems in the following order: MS-DOS, Windows 95 or Windows 98, and then Windows XP.
If you have Windows XP installed on a volume formatted as FAT, and you have another free volume formatted as FAT or FAT32, you can install Windows 98 to the free volume without reformatting your hard drive.
After ensuring that your hard drive is formatted with the correct file system, do one of the following:
If you want a multiple-boot system with MS-DOS, Windows 95 or Windows 98, and Windows XP, install MS-DOS, then Windows 95 or Windows 98, and then Windows XP.
If you want a dual-boot system with only Windows 95 or Windows 98, install Windows 95 or Windows 98, and then install Windows XP.
Important
Before creating a multiple-boot configuration with Windows XP and another operating system, such as MS-DOS, Windows 95, or Windows 98, review the following precautions:
Each operating system must be installed on a separate volume. Microsoft does not support installing multiple operating systems on the same volume.
If you have only one volume on your computer, you must reformat and repartition your hard drive to contain multiple volumes before you begin creating a multiple-boot configuration, unless you are simply installing another copy of Windows XP.
You cannot install both Windows 95 and Windows 98 in a multiple-boot configuration. Windows 98 is intended as an upgrade to Windows 95 and will try to use the same boot file.
You must install Windows XP only after installing MS-DOS, Windows 95, or Windows 98 to prevent MS-DOS or Windows 95 from overwriting the Windows XP boot sector and the Windows XP startup files.
Do not install Windows XP on a compressed drive that was not compressed using the NTFS compression utility.
You must use a different computer name for each operating system if the computer is on a Windows 2000 or Windows XP secure domain.
How to create a multiple-boot system with Windows NT 4.0 and Windows XP
Using a multiple-boot system with both Windows NT 4.0 and Windows XP is not recommended as a long-term solution. The NTFS update in Service Pack 4 for Windows NT 4.0 is provided only to help you evaluate and upgrade to Windows XP.
After ensuring that your hard drive is formatted with the correct file system, install Windows NT 4.0, and then install Windows XP.
Important
If you intend to install more than one operating system consisting of some combination of Windows NT 4.0 with either Windows 2000 or Windows XP as the only installed operating systems, you must ensure that you have installed Service Pack 4 for Windows NT 4.0. Windows XP will automatically upgrade any NTFS partitions it finds on your system to the version of NTFS used in Windows 2000 and Windows XP. However, Windows NT 4.0 requires Service Pack 4 to be able to read and write files on a volume formatted with the version of NTFS used in Windows 2000 and Windows XP.
Installing programs on more than one operating system
You must treat each operating system as a separate entity. Any programs and drivers you want to use must be installed under each operating system under which you want to use it. For example, if you want to use Microsoft Word on the same computer under both Windows 98 and Windows XP, you must start Windows 98 and install Microsoft Word. Then, you must restart your computer under Windows XP and install Microsoft Word again.
Notes
If you have more than one operating system on your computer, you can set the operating system you want to use as the default when you start your computer. For more information, click Related Topics.
Windows 95 or Windows 98 might reconfigure hardware settings the first time you use them. This can cause configuration problems when you start Windows XP.
Related Topics -
thanks alot for the help, i'll probably be doing this some time in the next few days. i jsut hope all my video editing software will work under xp.
and btw, i never got that e-mail, if it has all the same info, then i don't think it's too necessary. thanks again.
TA69
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 17:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 14:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 10:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 12:17
