folks - going to try out this CUDA encoding lark...
i have managed to get acceptable quality results using mediacoder, and a crappy old 8400gs card.
it produces the same quality video (well, to my eyes anyway) as autogk through an e6750 type CPU,
and slightly faster to boot....
i am considering buying a GTS250 which has many more cores, and should be a heap faster...
my question is: should i bother with a 1GB card, or will a 512M be sufficient? as the price difference is quite marked.
has anyone tried this, and been bothered to look at the GPU memory usage using a tool such as GPU-Z?
my thoughts are if it does not go near 512M then the cheaper card is the go.
cheers,
Results 1 to 1 of 1
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 18:36 -
AVCHD encoding enables CUDA
By kukkamies in forum Authoring (Blu-ray)Replies: 7Last Post: 14th Aug 2011, 18:55 -
need help solving excess memory usage in video capture
By philfr in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2011, 19:47 -
Cuda Encoding Feedback: Anybody?
By themaster1 in forum Video ConversionReplies: 1Last Post: 9th Dec 2009, 13:09 -
Premiere Pro Memory Usage is Extremely high
By jbandy1 in forum EditingReplies: 1Last Post: 31st Jan 2009, 04:07
