I just got an intensity pro and I havent gotten it to work yet. Im not sure what the issue is. I have a viewsonic vx2260wm monitor, this computer: http://www.bestbuy.com/site/Dell+-+Inspiron+Desktop+with+Intel%26%23174%3B+Core%26%231...&skuId=9698845, a ati radeon hd 4650 graphics card, and a xbox hooked up through hdmi. I dont know what the problem is, but I get a picture on my comp, then when I switch to the xbox I only get sound. What are the possible problems? Would an hdmi splitter fix this issue? Please help! If I cant figure this out then Im going to have to sell my card.
Closed Thread
The Intensity Pro won't accept HDCP coded material. If the XBox360 places an HDCP restriction on the HDMI output, you are out of luck. The analog component input would not have this problem. The XBox360 can output analog component 1080i or 720p with the right cable set.
You will need an HD monitor with analog component inputs to view the looped feed off the Intensity Pro.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
One thread per topic is enough. Continue in: https://forum.videohelp.com/threads/321292-Intensity-pro-xbox-help?p=1989457#post1989457
Modrator redwudz
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum Capturing and VCRReplies: 3Last Post: 12th Oct 2011, 17:56 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
PC to PC capturing with Intensity Pro
By luc2010 in forum Capturing and VCRReplies: 16Last Post: 29th Nov 2010, 20:02 -
Intensity Pro and PC Capture
By Tucker19 in forum DVB / IPTVReplies: 5Last Post: 12th Sep 2009, 17:30 -
Capturing from Intensity Pro
By KameronK in forum Capturing and VCRReplies: 3Last Post: 17th Apr 2008, 16:54
