Hello All,
I have an old panasonic vcr attached to my AT USB 650 via composite cables. I can capture the video fine, using uled (came with some hardware) and all. However, the stream has scrambled lines on top and bottom. Is there a simple way to get rid of them?
I have tried VDub but when I go to capture it hangs while doing screen capture. So not sure what to do?
The lines at the top are probably flagging. You'll need a time base corrector to fix that. The garbage at the bottom (~10 lines) is VHS head switching noise. All VHS tapes have that. You don't see them on TV because TVs hide the four edges of the picture. The noise at the bottom can be cropped away or masked. If the flagging at the top isn't too large you can crop or mask that too.
How do you mask? What software do I use?
Thanks for being so helpful -
You can mask in virtualdub although I'm not sure of the exact setting.
VirtualDub can crop while capturing: Video -> Cropping... Be sure to crop an even number of scanlines from the top and bottom (not odd numbers). If you are going to DVD you need to restore the frame to the full 480 line height afterwards. You can do that in VirtualDub too -- with the Resize filter's Letterbox option.
Thanks for all the help. But two questions:
1) When I use VDub It herks and jerks when I press start capturing - but looks fine in preview. Also, in ULead no herk and jerk
2) VDub does not give me sound either.
I am using a Panasonic VCR attached to my ATI USB 650 which has hardware encoding. I am using composite connection, and maybe that is why I have no sound. But, I get sound fine with ULead and MovieMaker. -
VirtualDub captures uncompressed YUY2 from the 650 USB. Did you select a compression codec? Video -> Compression... I recommend HuffYUV for video capture.
I think the default is not to play the sound while previewing and capturing. You can turn it on via the menus. Audio -> Enable Audio Playback.
Convert VHS or U-matic tapes to any digital format
By predatorz6 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2012, 07:36 -
Convert VHS tapes to digital files
By Rogerwodehouse in forum MacReplies: 5Last Post: 20th Jul 2011, 14:55 -
Newbie looking to archive VHS tapes
By brightview in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2011, 20:11 -
Wavy lines on tv reception (tapes too!)
By JudgeGarth in forum DVB / IPTVReplies: 4Last Post: 27th Feb 2008, 10:56 -
help with VHS tapes with lines int he middle
By curt1sw in forum RestorationReplies: 6Last Post: 14th Dec 2007, 07:51
