Using a Kodak Easyshare Z1085, I'm shooting HD video that is 1280 x 720 with a data rate of about 12000kbps and a frame rate of 30 frames per second, with audio at 128kbps mono and 16kHz sample. The camera saves the video in Quicktime ".MOV" format.
My question is simple: I need Windows software that will let me create home movies from these files. I don't need any fancy effects. The main requirement is that the software does not degrade the quality. Everything I've tried seems to take forever doing re-encoding, and end up degrading the quality.
I want to combine my raw video into movies that I can burn to Blu-Ray disc or ISO without sacrificing video quality.
Advice and suggestions most welcome. Thank you!
Tried multiavchd? No reconversion if it's avchd or blu-ray compliant.
Need help creating a BD-R that will play on Blu-Ray players
By cmw in forum Authoring (Blu-ray)Replies: 11Last Post: 28th Jul 2011, 09:59 -
Creating a Blu-Ray from TV Shows
By dbanimal in forum Video ConversionReplies: 10Last Post: 23rd Feb 2011, 13:31 -
Uncompressed mov / Blu Ray authoring
By brettwtfi in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Mar 2010, 13:25 -
How to enocode MOV to it can play back on Blu-Ray
By vatkat234 in forum Video ConversionReplies: 1Last Post: 28th Nov 2009, 11:28 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43
