Hi, I just received my new Cam Panasonic HDC-SD700. Nice picture, easy to use, etc..
But once I try to merge (join) some MTS file to one, I detect a audio delay INCREASING with the number of files merged, in the resulting file. I am using the tool TsMuxeR (1.10.6).
I use this tool for my Pana DMC-TZ7, Sony CX11, with NO problem ! Resulting file is nice !
After trying many posibility: de-mux, re-mux,.. and many tools: emic MTS converter, mpeg edit ultimate, multiAVCHD, SUPER, TSDemux,...
I finaly suspect that the Panasonic MTS file is NOT correct: audio stream is longuer than the video stream (video is N frame, audio is N+1 frame)
So I get around 40ms delay increasing for each MTS file joined (for 10 files, I get 400ms delay !!!!!)
I would like to avoid converting to other format (keep quality AND 5.1 sound). I do some test with Vegas 9, Corel XP, AVS, converting time is looooonnnnggg and 5.1 sound is lost or not working !
Any body have a solution or idee with this Pana MTS bugy files ??
Thanks to all
Marc
Results 1 to 15 of 15
Maybe try videoredo 4 preview. See http://www.videoredo.net/msgBoard/showthread.php?t=15759
Thanks Baldrick!
I will try this afternoon!
I will also try avidemux, mkvtoolnix and elecard AVCHD.
Regards -
Hooops !
To the videohelp moderator or administrator: the title is ....SD700... (not 70)
Thanks -
I try Elecard AVCHD editor and it seem to work fine with MTS files of Panasonic SD700 !
http://www.elecard.com/products/products-pc/consumer/avchd-editor/
This editior is very simple and do juste what I need : merging (joining) MTS files.
But !
I try with 8 MTS files (5min video, 500mb), time: 20 min to join
I try with 20 MTS files (50 min video, 4.5gb), time: 24h and is not finished !!!
Also, you have to manualy drag and drop each MTS file in the editor to get correct order ! else files are mixed.
So, still need some improvement for this software!
I keep you informed..
Marc -
I have an SD60...and same problem...audio is longer than video by 2-3 frames. I've spent a month trying to find a solution for simple joining...Here is what I do...
Join and remux to mkv...1st using tsdemux to join and generate the timecode file (I use excel to prepare the sequence and run the command line)...then dump everything to mkvmerge which uses the timecodes to sync...and play in wdtvlive without problem...this is my work flow for viewing at home. For simple joining, I found no other way with free tools...
However, FFMPEG doesn't like this MKV...so if I want to do a DVD...I batch convert the MTS files first using FFMPEG...I demux the MTS then encode with FFMPEG using the "-shortest" param to cut short the audio...then join the MPEG using tsmuxer...again using excel to prepare the sequence...however, the new mpeg file still has minor out of sync...so I have to demux it and run the AC3 through audacity to shrink the audio...and then remux the new AC3 back...slightly convoluted but ti works...
If you want to keep to the mts...you can use xport to get info on frame count...use the frame info to calc the duration...use tsmuxer to trim...then use tsmuxer again to join...then demux using tsmuxer and get the frame count...then shrink the AC3 as above and remux it back...
NLE editors that uses the video timecode and smart-rendering should work for quick join without problem...editors that snap to longest stream will get you 2 blank frames on every join...
Hope these helps.Last edited by dwRK; 27th Jul 2010 at 04:41.
glad to help.
my latest preference...keep the mts/m2ts...since ffmpeg accepts this...so...xport->excel->tsmuxer(trim)->tsmuxer(join)...I just joined 160+ files with perfect sync...
also i use batch files and macro to simplify tasks...
fyi...no need to demux, shrink ac3 and remux...for some reason the trim now works...probably user error before...
p/s...i saw somewhere that sony and others got this problem also...so is not a panasonic only issue...Last edited by dwRK; 3rd Aug 2010 at 02:27.
sorry for the confusion. what i meant to say is that joining the files using this 3rd method...the resulting mts/m2ts files can be encoded using ffmpeg...
i have hundreds of files to do, so i use batch files and command lines instead of gui. you can use gui for a few files...here you go for the batch files...
step 1. use xport to get number of frames. 1st "for" command dumps xport output to info1.txt. 2nd "for" command cleans up and dump the file name and number of frames/fields to info2.txt. 3rd "for" displays it in the console for checking. i run this .bat file in the same directory with the .mts. it can take some time to run if you have lots of files or files are long...try with a few short ones...
Code:@echo off del info1.txt del info2.txt for %%a in (*.mts) do for /f "usebackq skip=27 delims=," %%s in (`c:\apps\av\xport\xport -phs %%a 1 1 1`) do echo %%a %%s >> info1.txt for /f "usebackq skip=2 tokens=1-5" %%f in (`find "coded pictures = " info1.txt`) do echo %%f %%j >> info2.txt for /f "tokens=1-2" %%g in (info2.txt) do echo %%g %%h pause
step 2. open info2.txt and copy the filename and frame/field info into excel cell A17 and then text-to-column. i use excel macro to generate the meta files for tsmuxer. it also generates the batch file for cutting. you can work backwards from the macro what goes where in the excel sheel. note that the directory must include "\" at the end. also I use the cells for debugging...hence the codes are a bit sloppy...also there are extra bits not normally used...sorry...
Code:Sub dw_cut() Dim progdir, metadir, metaname, sourcedir, outputdir, batname As String, starttime, endtime, retval As Integer Sheets("cut").Select Range("A17").Select progdir = Range("B3").Value 'e.g., c:\apps\av\tsmuxer\tsmuxer.exe metadir = Range("B4").Value 'e.g., c:\apps\dwvid\temp\ sourcedir = Range("B5").Value outputdir = Range("B6").Value Application.ScreenUpdating = False Do Until Selection.Offset(0, 0).Value = "" Selection.Offset(0, 2).Value = Selection.Offset(0, 1).Value / 2 'convert fields to frames Selection.Offset(0, 3).Value = Selection.Offset(0, 2).Value * 40 'convert to miliseconds If Selection.Offset(0, 4).Value > 0 Then starttime = Selection.Offset(0, 4).Value Else starttime = 0 End If If Selection.Offset(0, 5).Value > 0 Then endtime = Selection.Offset(0, 5).Value Else endtime = Selection.Offset(0, 3).Value End If Range("c8").Value = "MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --cut-start=" & starttime & "ms " & "--cut-end=" & endtime & "ms --vbv-len=500" Range("c9").Value = "V_MPEG4/ISO/AVC, " & """" & sourcedir & Selection.Offset(0, 0) & """, fps=25, insertSEI, contSPS, track=4113" Range("c10").Value = "A_AC3, " & """" & sourcedir & Selection.Offset(0, 0) & """, timeshift=0ms, track=4352" Range("c11").Value = "S_HDMV/PGS, " & """" & sourcedir & Selection.Offset(0, 0) & """,bottom-offset=24,font-border=2,text-align=center,video-width=1920,video-height=1080,fps=25, track=4608" metaname = "" & metadir & Selection.Offset(0, 0) & ".meta" Open metaname For Output As #1 Print #1, Range("c8").Value If Range("B9").Value = 1 Then Print #1, Range("c9").Value If Range("B10").Value = 1 Then Print #1, Range("c10").Value If Range("B11").Value = 1 Then Print #1, Range("c11").Value Close #1 Selection.Offset(1, 0).Select Loop batname = "" & metadir & "runcut.bat" Range("c13").Value = "for %%a in (*.meta) do " & """" & progdir & """ """ & metadir & "%%a""" & " """ & outputdir & "%%~na.m2ts""" Open batname For Output As #1 Print #1, Range("c13").Value Close #1 If Range("J4") = 1 Then retval = Shell(batname, 1) End If End Sub
Step 3. run runcut.bat to trim the files...i use a batch file instead of running tsmuxer directly in excel because i want it run one by one...
Step 4. run fixname.bat to fix the files names...i was lazy to code it properly in excel...so i use this .bat file to fix/revert to the original names...
hope these helps...Code:@echo off" for %%a in (*.m2ts) do for /f ""tokens=1-4 delims=."" %%b in (""%%a"") do if %%c == MTS rename %%a %%b.%%c"Last edited by dwRK; 4th Aug 2010 at 01:27.
Great job !
I do all. I test with 6 files and I get new files litle smaler.
I join the new files in a test file for my WDTV box.
I did not yet test (saterday yes) ...but it sems well gone !
I just have one issue
, I test with 6 files (0038 to 0043), i get only 5 new files (0040 was missing)
This is the info2:
00038.MTS 744
00039.MTS 336
00041.MTS 2496
00042.MTS 96
00043.MTS 264
and this is the info1:
00038.MTS coded pictures = 744
00038.MTS Ending audio to video PTS difference = 2880 ticks
00039.MTS coded pictures = 336
00039.MTS Ending audio to video PTS difference = 2880 ticks
00040.MTS Ending audio to video PTS difference = 2880 ticks
00041.MTS coded pictures = 2496
00041.MTS Ending audio to video PTS difference = 2880 ticks
00042.MTS coded pictures = 96
00042.MTS Ending audio to video PTS difference = 2880 ticks
00043.MTS coded pictures = 264
00043.MTS Ending audio to video PTS difference = 2880 ticks
is there a problem or bug or other ?
Thanks again for your help
Marc -
yes...a "bug" on my part...
if you can use xport to just check your 00040.mts on the cmd line...you should get the coded picture count.
the error is on "skip=27" in the batch file...try 26 or 25...i wanted to limit the amount of info to capture...so most likely the xport report for 00040.mts has 1 line less and so the info was skipped and not captured in info1... -
Hi dwRK,
Is there any way to fight that audio delay using tsMuxerGUI, please ? Any possibility to edit meta file etc.
thanks -
Yes...you can trim it in the gui...
I don't believe it is an audio delay...I think it is just a bit longer... -
Thank you. For me it's to complicated not to use GUI. Do I need to go to DOS PROMPT ?
PS. AUNSOFT releases FINAL MATE which claim to join .mts file not loosing quality. Gonna try it
panasonic HDC-TM700 inport files,how to?
By cesarin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jun 2014, 08:05 -
manually copied of .MTS video files back to Panasonic HDC-90 memory card
By Rovi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Jan 2012, 12:17 -
panasonic hdc-hs9 .MTS to .DV problem
By klein in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Dec 2011, 10:43 -
Opening files from Panasonic HDC-HS700 on a Mac
By Philip1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Oct 2010, 11:18 -
Panasonic HDC-SD60 .MTS help
By BookwormSkates in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Sep 2010, 10:21
