When attempting to record I get this message : Could not open wave/audio device.
I've installed Lame_enc.dll in the mp3directcut folder. Any ideas on how to get this thing to work ?
Results 1 to 12 of 12
mp3DirectCut is an mp3 editor.
What is it that you're trying to do? -
I'm trying to edit an mp3
One loooong single mp3 track. Want to make several tracks. Having it detect the pauses, which I have done successfully to my approval. Separating songs so I can skip forward, without skipping through the whole thing. mp3DirectCut detected 63 pauses. I would like to separate each song, or group of songs at the pauses with a track. Then burn the the tracks to a CD, or an mp3 device. Will mp3DirectCut allow me to do this ? -
^ ^I'm trying to edit an mp3
Yes, this is easy enough.
^ ^Having it detect the pauses, which I have done successfully to my approval. Separating songs so I can skip forward, without skipping through the whole thing. mp3DirectCut detected 63 pauses. I would like to separate each song, or group of songs at the pauses with a track. Then burn the the tracks to a CD, or an mp3 device.
I don't think that mp3DirectCut will do all of this stuff though. -
Ok. How do I do this ?I'm trying to edit an mp3
One loooong single mp3 track. Want to make several tracks. ^ ^
Yes, this is easy enough. -
Well,Ok. How do I do this ?
File > Open
to load the mp3 file.
Then use
'Set Begin' and 'Set End'
to choose the section.
Then
File > Save all audio
to save it.
Then repeat for the other sections, one at a time. -
Ouch. I guess that is better than doing with out. I was looking for something to do it with little effort on my part. But, that'll work too. I feel kinda stupid now.
Visual MP3 Splitter and Joiner will do what you want
http://www.maniactools.com/soft/mp3-splitter-joiner/index.shtml?version=6.0 -
Easy Peasy...Select 'File -> Save Split'...One loooong single mp3 track. Want to make several tracks. Having it detect the pauses, which I have done successfully to my approval. Separating songs so I can skip forward, without skipping through the whole thing. mp3DirectCut detected 63 pauses. I would like to separate each song, or group of songs at the pauses with a track. Then burn the the tracks to a CD, or an mp3 device. Will mp3DirectCut allow me to do this ?
How I can cut TS files ?
By Torresinho in forum EditingReplies: 1Last Post: 14th Feb 2010, 16:15 -
Is there anyway to know whether a video has been cut or not?
By RiverDD in forum EditingReplies: 6Last Post: 6th Jun 2008, 16:31 -
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 03:28 -
Cutting/Splitting an MP3 Audio with MP3Direct Cut
By UmmAddan in forum AudioReplies: 2Last Post: 22nd Jan 2008, 19:03 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
