    Jul 2007
    Old Europe
    Hello,
    I record TV with my DVB-T board on my PC but the files are large (several gigs for a movie, even in SD). Some TV programs are in SD, some in HD. I'd like to resample them in order to reduce disk space used. However, I'd like also to keep the same quality felt when watching. I'd like SD programs to stay in SD and HD programs to stay in HD quality. Here's the media info for an SD program:
    General
    Complete name                    : /home/charles/Desktop/14 - ARTE - Mon 24 May 2010 02:56:54 AM CEST.mpeg
    Format                           : MPEG-TS
    File size                        : 3.73 MiB
    Duration                         : 6s 68ms
    Overall bit rate                 : 4 904 Kbps
    Video
    Menu ID                          : 1000 (0x3E8)
    Format                           : MPEG Video
    Format version                   : Version 2
    Format profile                   : Main@Main
    Format settings, BVOP            : Yes
    Format settings, Matrix          : Default
    Duration                         : 6s 40ms
    Bit rate mode                    : Variable
    Bit rate                         : 4 273 Kbps
    Nominal bit rate                 : 15.0 Mbps
    Width                            : 720 pixels
    Height                           : 576 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 25.000 fps
    Standard                         : PAL
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Bits/(Pixel*Frame)               : 0.412
    Stream size                      : 3.08 MiB (83%)
    Audio #1
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 2
    Mode                             : Joint stereo
    Mode extension                   : Intensity Stereo + MS Stereo
    Duration                         : 6s 48ms
    Bit rate mode                    : Constant
    Bit rate                         : 192 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Video delay                      : -258ms
    Stream size                      : 142 KiB (4%)
    Language                         : French
    Audio #2
    Format                           : MPEG Audio
    Mode                             : Joint stereo
    Duration                         : 6s 48ms
    Bit rate                         : 192 Kbps
    Language                         : German
    Text #1
    Format                           : DVB Subtitles
    Language                         : French
    Text #2
    Language                         : German
    Text #3
    Language                         : French
    And here's for an HD program:
    General
    Complete name                    : /home/charles/Desktop/video.mpg
    Format                           : MPEG-PS
    File size                        : 9.21 MiB
    Duration                         : 10s 278ms
    Overall bit rate                 : 7 517 Kbps
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L4.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Bit rate                         : 7 368 Kbps
    Width                            : 1 440 pixels
    Height                           : 1 080 pixels
    Color space                      : YUV
    Bit depth                        : 8 bits
    Scan type                        : Interlaced
    Scan order                       : Top Field First
    Bits/(Pixel*Frame)               : 0.189
    Stream size                      : 9.03 MiB (98%)
    Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics         : BT.709-5, BT.1361
    Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Could you give me your suggested settings in AviDemux in order to resample them without losing quality? (frames per sec., bitrate, audio format, video format, container, etc.)
    Thanks!
    Lower the video bitrate and keep everything else the same. Use mpeg4 avc (h264) video encoding and if you want a specific file size use 2-pass video size and set the file size or if you don't need that try use constant rate factor quality encoding(try use around 23).
    See screenshots:
ID:	1953Click image for larger version
    Jul 2007
    Old Europe
    Thanks, I'm going to try these settings.
    Export as a mp4.
    And if you get problems with avidemux you can try staxrip, handbrake , xvid4psp or megui.
    Jul 2007
    Old Europe
    I'd like not to use x264 if possible, as I have experienced problems on some friends computer... What do you suggest?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Then try mpeg-4 asp xvid. Use similar settings.
    But you should be able to get better quality with h264.
    Jul 2007
    Old Europe
    Thanks. Also: Same settings for both SD and HD, right?
    Jul 2007
    Old Europe
    Were these settings for SD or HD? I think this is for SD. What settings should I use for HD? Thanks.
