hello
why when im taking shots from videos they are always blurred and not sharpen?
im capturing in km player pressing ctrl+c to take shot and the pictures always blurred even that the movies are high def
is there anyway 2 resolve this?
Capture uncompressed (sd) to Huffyuv or with a hardware video encoder.
HD is more difficult and depends on source device. Learn to do SD first.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You are probably dealing with an h264 source that is not effeciantly handle-able on your computer. So, your software will be sluggish at decoding the source inside your players window, and it will probably look blury like you described. I have similar issue with my mini corder.even that the movies are high def is there anyway 2 resolve this?
I thought the world ended, waisted money, bla bla, but then I tried something. I re-encoded the source to xvid out of curiosity. Well, as it turns out, the source plays fluid and there is no blurry motion and all that nonense I was (as still do have) during play if I play my raw sources. Its not that my system can't handle h264, but rather in this case, it was the origin--a new source medium, and it produces fuggy sources that my tipicle pc can't handle as well.
You may need to "beef up" your pc and/or graphics card. Or, I could wrong about your situation.
-vhelp 5380 -
i was taking about taking shots from hd\sd movies
not playing them, playing them i have no problem at all, they are working 100% smooth
i said when im trying to take picture from movie most of the times the image come out blurry
my question is how can i take smooth pictures, from sd\hd films
cheers -
For 1080i, VLC allows still snap with deinterlace modes active, or you can cap single fields. 720p can be capped as a frame.
What is your source format?Recommends: Kiva.org - Loans that change lives.
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
My Caps Come out very Blurred
By zxfactor in forum Capturing and VCRReplies: 9Last Post: 17th Feb 2009, 06:10 -
Blurred Text on DVD Menu
By boofer in forum Authoring (DVD)Replies: 3Last Post: 10th Jan 2009, 17:45 -
Streamclip output blurred
By bijones2 in forum EditingReplies: 0Last Post: 14th Jun 2008, 06:37 -
DVD Lab - menu text blurred (PAL)
By BeachNut in forum Authoring (DVD)Replies: 12Last Post: 21st Jan 2008, 06:12
