I have an AVI in which I want to split the audio and video so that I can add another audio file to it (and resync hopefully). I have heard AVIdemux is the best tool for this but I have no clue how to make it do this. I have searched and searched online for some "How To" and still no luck.
So my apologies for such a newbie questions, but can anyone help me out with this?
Thanks in advance!
	Load the video into avi demux, then click on Audio->Save to save the audio stream. if you just want to change the audio track, click on Audio -> Main Track, then change the audio source to one of the supported external options, and select your audio stream file. Click OK. Make sure video and audio are both set to Copy, then click on File -> Save -> Save Video to save your new video. Read my blog here.
  VCRs with separate video/audio tracking?By Relayerman in forum RestorationReplies: 7Last Post: 16th Oct 2014, 05:47
  Trying to separate music from the rest of the audio in a video.By walkerrhodes in forum AudioReplies: 8Last Post: 21st May 2011, 04:18
  Canīt properly separate audio from videoBy dexter30 in forum AudioReplies: 2Last Post: 29th Oct 2009, 21:44
  Use to author from separate audio and video streams?By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 14th Jul 2009, 06:41
  avidemux- audio comes out faster than videoBy DaneClark in forum EditingReplies: 1Last Post: 11th Jul 2009, 19:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
