I'm converting an avi to DVD and for testing purposes, I converted it using AVStoDVD, burned on the DVD and everything was OK, except for some interlace artifacts.
Please see an example http://www.100fps.com/distortion3.jpg
Now I want to convert again the original avi and need to check "deinterlace" in the program(AVStoDVD). The problem is: when I click on the start button, I get "Avisynth open failure: Script error: there is no function named "LeakKernelDeint"
C:\Docume~1\username\LOCALS~1\Temp\DVD_1_movie_1.a vs, line 7)".
What does it mean?
Here's the script. I'm not familiar with it.
I appreciate any help.Import("C:\Arquivos de Programas\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\Documents and Settings\username\Meus documentos\movie.avi", CacheFolder = "C:\DOCUME~1\username\LOCALS~1\Temp")
Audio = A2DAudioSource("F:\Documents and Settings\username\Meus documentos\movie.avi", CacheFolder = "C:\DOCUME~1\username\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.LeakKernelDeint(1,10,false,false)
Video = Video.AddBorders(8,0,8,0)
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
you normally wouldn't deinterlace a dvd - if it's properly done, your dvd player will take care of the interlacing.
Did you look at it in the dvd player, or on pc (if pc, what software?)
what format was your original source? use mediainfo if you don't know. AVI is just a container and can hold many different kinds of things.
Was it interlaced to begin with? -
DVD player and PC(VLC media player).
I have captured VHS using HFYU and AC-3 codec. -
@user2008
in the AviSynth script the following line:
is missing. You can add it at the beginning of the AviSynth script ('Title Edit'/'AviSynth' -> toggle off 'Auto AviSynth Script').Code:LoadPlugin("C:\Arquivos de Programas\AVStoDVD\Lib\LeakKernelDeint.dll")
BTW this error is quite strange: what AVStoDVD release are you using?
Bye
Help. Avisynth Error Message "no function named limitedsharpen"
By Pitorasilo in forum Video ConversionReplies: 7Last Post: 27th Dec 2010, 06:13 -
AVIsynth: is there such a function like repeat/until or for/next ?
By vhelp in forum EditingReplies: 4Last Post: 8th May 2010, 05:20 -
AviSynth function to add SUP subtitles?
By MilesAhead in forum SubtitleReplies: 11Last Post: 3rd Feb 2010, 13:16 -
There is no function named "BlackmanResize"
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2009, 07:54 -
Help. Avisynth Error Message "no function named deblock"
By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 27th Sep 2008, 23:45
Thanks. Problem solved.
