I am a newbie. My converted video from a Lumix camera loses audio about half way through. Why?
The downloaded camera file works fine. But the problem starts after conversion. Aud/Video sync well until the half way point.
I am using the freebie Any Video Converter.
Try with something else first like Xmedia Recode or WinFF or avidemux.
If that wont help then PLEASE give more information like
What is the source details? Video and audio codecs, etc. Identify with mediainfo.
What are you converting to? -
Hi Baldrick
Here is a little more info. I am trying to convert a HD AVCHD file called a .mts. All I want to do is take this hi def file and put it on youtube or vimeo.
So first I tried to convert it to a AVI. . Video was set up as MPEG4E = H2.64 AVC Codec. Audio was MP3 Video converted, showed up in a folder with no sound
Then I tried to set the format to MPEG4 , Video H2.64, Audio AAC.....that did not save at all in the saved folder.
Audio is half the speed to video
By pixaren in forum Capturing and VCRReplies: 1Last Post: 2nd Nov 2010, 06:40 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
when WAN is connected to the router the network speed drops to half...?
By stars in forum ComputerReplies: 18Last Post: 19th Feb 2008, 11:44 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55 -
no audio on converted video
By beanosirra in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2007, 13:19
