I've got several mp4 videos that I want to join into one output video. All the mp4s have the same characteristics except for duration.
_______________________________
For one of the MP4 files, MediaInfo sez:
Video
Format : AVC
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 10mn 33s
Bit rate mode : Variable
Bit rate : 501 Kbps
Maximum bit rate : 1 171 Kbps
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.116
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 10mn 33s
Bit rate : 118 Kbps
Maximum bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
I wanted to do things as simply as possible because I'm new to video editing, so I just used "Copy" for both audio and video input and first "avi" and then "mp4" for the output format.
I opened the first file and appended all the others to it. Every time, I got the pop-up that said "H.264 detected" and talked about B frames. I said no every time. Avidemux never crashed on me.
I read something about audio going out of sync if it's VBR, so I selected "Build VBR Time Map" from the Audio drop down after I had all the inputs joined together in avidemux.
Everything's great inside avidemux. I've looked at the input and output side by side throughout the joined result. I wish I could get an output that was OK, but after 2 different failures, I decided to come here for help.
My AVI output file has no video in Winamp, DivX Pro Player or Windows Media Player.
My MP4 output file has very high video values (everything's washed out and nearly white) where the second and subsequent MP4 input files are, but where the first input file is, the video's OK. The audio and video seem to be in sync throughout the MP4 output file.
Is there some easy way to get a trouble-free output file? TIA.![]()
Trying to convert AVI to MP4 (for iPad) -- Avidemux won't install
By monkeypack in forum Video ConversionReplies: 4Last Post: 28th Nov 2011, 09:18 -
MOV format from video camera>avidemux>mp4 out of sync
By duhmez in forum Video ConversionReplies: 2Last Post: 7th Apr 2011, 21:36 -
AVIDeMux - H264 (.mp4) to .avi - Audio Sync 1000ms
By nlvraghavendra in forum Video ConversionReplies: 3Last Post: 9th Mar 2010, 15:50 -
Avidemux - best quality from wmv to avi/MP4/H264?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2009, 05:57 -
MP4 video to avi or mpg
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2007, 13:59
