    May 2010
    Jersey Shore, NJ USA
    I know there is a thread here on this topic, but for one, it's 5 years old and I really didn't want to resurrect a 5 yr old thread, and two, it didn't help me with my specific issue, so I figured I would just start a new thread. I'm sure there is an easier answer to this than in the other thread as well.
    I downloaded a torrent that turned out to be 95 rar files. I selected all of them (as described in the other thread) and extracted them into a separate folder. The other thread talked about a cue and bin file, of which I have neither. I have one folder called VIDEO_TS containing mulitple BUP/IFO/VOB files.
    I used Super DVD Creator to make my DVD's, a very user friendly program and it suits my needs. When I select all of those files for the program, it creates 8 subtitles that gives me 8 titles in the Main Menu. This doesn't appear to be correct to me. Can anyone please tell me the correct way to make a DVD out of these files, preferrably with Super DVD Creator??
    Thanks in advance.
  2. ImgBurn: Drag VIDEO_TS folder to compilation window, burn.
  3. Banned
    Freedonia
    It sounds like your extracted files are already in the correct format, so all you need to do is burn them with ImgBurn as jagabo said. There are guides on how to use ImgBurn for this. It's not hard.
    Thank you for not digging up an old thread and posting to it. Thank you. We much prefer that you just start new threads like you did than to add to old threads from years ago.
  4. Mod Neophyte redwudz's Avatar
    USA
    Sorry, this forum is for posting user guides. Moving you to Newbie/General Forum.
    May 2010
    Thanks for the tips!! ImgBurn worked like a charm!! I had to do a little hunting and pecking with figuring out how to point it to the correct folder, but once I got that accomplished, it did everything for me! Much appreciated!
    And I'm familiar with some basic forum rules, like not raising the dead!
  6. @jefflb
    As you said "ImgBurn worked like a charm!!"
    Yeah, ImgBurn is a wonderful and an excellent gift to us by the author(s), for burning VIDEO_TS folder.
