ok is this how it goes? i downloaded the tmpgenc and plugin. unzip then open them. do i open the tempgenc then the plugin. it says to open the plugin after the tmpgenc. then when i do that it says cant find specified file. please someone walk me through the steps for getting this right i am having to many problems.
are you referring to the .vfp plugin? if so all you need to do is run tmpgenc in the same folder to register it. if that fails there should be an installation .bat or .reg in the distribution package. oh, and i'd like to add a pre-emptive '**** off *******!' should koalabear respond to this thread
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
Nero Blu-Ray/HD plugin problems
By lostinlodos in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 19:01
