Im trying to capture xbox 360 gameplay with the card. I just got it but I just cant hook it up. I have it in the pci slot but this video I have tried isnt working for me: http://www.youtube.com/watch?v=DcSic-wgS3Y
I need somebody to take me step by step through this. I can't use component so that is out. I also have this computer which idk if it could be the problem or not: http://www.bestbuy.com/site/Dell+-+Inspiron+Desktop+with+Intel%26%23174%3B+Core%26%231...&skuId=9698845
I also have the Ati radeon hd 4650 video card installed. I dont know if those things matter or not but somebody please help!
Results 1 to 30 of 31
Describe your computer specs.
PCI slot or PCIe slot?
Why can't you use analog component in?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
There are lots of problems with the Intensity drivers. A lot of people here have talked about reverting to version 3.4 drivers rather than the latest. If you search this site you'll see the posts.
No way. Explain more your computer specs and needs.
dang... nvm it still doesnt work.... I use the same monitor for xbox and pc, and when I switch to hdmi for the xbox it takes me to a black screen but I can still hear audio. I have my pc hooked up through dvi to the monitor. What specs do you want exactly?
2.93 ghz processor. 1tb hard drive 8 gigs of ram ati radeon hd4659 video card viewsonic vx2260wm monitor what else?
here you go
http://blackmagic-design.com/support/software/archive/?series=intensity&category=Windows
Yep drivers are very bad and very buggy. Media Express has issues as well. Just keep uninstalling and reinstalling while trying different drivers. It'll eventually work that way. But don't EVER give up and say your card is faulty, because that usually never happens with this card and you don't need to go through the mess of sending it in. -
On my droid right now.... wat are all the different drivers? Can I get them all from the blackmagic site?
Does the fact that I get audio but no video seem weird or is that common? I mean is there no chance that it could be thecable or something?
just curious... is there something special about the 3.4 drivers? Im downloading now, but if they dont work what others should I try? Sorry for all the questions but I just wanna hook this dang thing up.
i downloaded the 3.4, but when i install it says i need a firmware update.... should i skip that part or what?
Ok im really getting annoyed... that didnt work either but i dont know if i installed it right. Can somebody who has done this without a splitter post what theirs is like or some more suggestions?
very new... like 2009. im thinking it has something to do with hdcp... wat can i do if this is the problem?
I have figured out that it is an hdcp problem soooo... here is the deal. I only have vga or dvi available on my monitor since hdmi is a no go. Is there some way that I could get a component to vga cable so that I could plug it into my monitor and still record or is that not possible?
Get a component cable for the xbox 360. Than you can still record in high def.
I assume that the intensity has an option to record component input.
That is how I record from my xbox 360 to my hauppauge hd pvr.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
since i only have an hdmi port on my monitor could i hook it up with component and use this: http://www.hdtvsupply.com/component-to-hdmi-adapter.html or would that not work?
As long as the xbox 360 will put out a component signal you should be ok with that component to HDMI converter (I wish it explicitly said what input resolutions and frame rates it supported). You can check the xbox 360 by running component from it to the Intensity Pro and seeing of you can capture.
You may get a frame or two of lag on the converter's output though. That would make fast action games a little harder to play.
Note that AACS (the encryption used on Blu-ray discs) rules require that no player manufactured after 2010 be able to output high def analog. After 2013 there will be no analog output allowed at all. I believe all the current players have the ability to disable the component output at any time so it's possible the game manufacturers could use that feature to keep you from recording in the future.
blackmagic intensity pro xbox 360 help
By tehshame in forum CapturingReplies: 11Last Post: 18th Nov 2010, 15:24 -
Help capturing from Xbox 360 with Blackmagic Intensity Pro
By SkinnyRabbit in forum CapturingReplies: 10Last Post: 1st Oct 2010, 10:44 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum CapturingReplies: 6Last Post: 15th May 2009, 17:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum CapturingReplies: 0Last Post: 22nd Apr 2009, 15:27 -
blackmagic intensity / Xbox 360 / Adobe premiere pro CS 3
By jonakangou in forum CapturingReplies: 11Last Post: 17th Jul 2008, 00:42
