I have over 2000 movies already in a movie date base program, they are in pouches that hold 200, each page has 4 slots. I would like a program to download so I can locate a movie in which pouch and what slot Is there such a thing out there? thanks 2boot
you could try this one http://www.movieorganizer.com/ i use it and is a good program and is free.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
I should be more clear. I have all of my movies in a movie data base program, but all of my movies are stored in pouches that hold 200 movies four to a page. What I would like to have is a program I could list the pouch the page and the slot on the page so they could be located quickly. Is there such a thing to be had? thanks 2boot
the program i suggested will let you make locations for the disks. but you would have to re enter all the information. since i don't know what you used to make your current data base i can't say if it would do what you wanted. but you could add the locations with the current titles in your current data base. i am sure there are other programs to do what you want, but the one i mentioned dose work well. here is a screen shot of the program:
Need a program to replace Windows Movie Maker
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2011, 04:11 -
Movie Screenshot Program?
By Junkee in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2010, 05:15 -
What program will tell me the codec a DVD movie uses?
By seskanda in forum Newbie / General discussionsReplies: 8Last Post: 24th Sep 2008, 14:01 -
Need free good advanced movie-editing program
By LoveMyslf in forum EditingReplies: 11Last Post: 26th Jun 2008, 12:59 -
Help To Buy a Movie Program
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 5th May 2008, 12:14
