How to record a live video stream into several segments with a maximum duration, or maximum size, or maximum number of frames?
I want to grab a live stream (either HTTP, RTSP, MMS, RTMP, etc.) and record it into these files :
rec-1.mpg (or .avi , or .mov, or .flv, etc., it makes no difference)
rec-2.mpg
rec-3.mpg
rec-n.mpg
each recorded file must be long, for example, at most 500 frames.
Which program enables me to do this, and how?
thank you![]()
I wouldn't even THINK of trying that "on the fly"...if that is indeed what you are thinking of.
yes that's what i meant
why should it be not feasible?
the recorder starts recording the stream to the file segment-1.mpg, starting from frame 0
when the recorder reaches the frame number 500 ,
it closes the file and opens a new one: segment-2.mpg
then, it starts recording frame 501 to the new file, until it reaches frame 1000,
and so on
it doesn't seem so impossible -
Flash Media Live Encoder can do that by time duration or file size. It's a free download from Adobe.
http://www.adobe.com/products/flashmediaserver/flashmediaencoder/?sdid=FCOQP
Best wishes,
Eye for Video
restream a live stream
By nerojan in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2016, 13:29 -
How to Stream Live TV to my website??
By afghanistan-culture in forum Video Streaming DownloadingReplies: 8Last Post: 29th Feb 2012, 21:00 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 07:14 -
Using DV Camcorder to Stream Live
By johnwenzel in forum Video Streaming DownloadingReplies: 3Last Post: 9th Sep 2009, 06:41 -
Live stream recording: how to make it continuous
By igorek in forum Video Streaming DownloadingReplies: 1Last Post: 25th Oct 2008, 20:29
