Hello,
I am trying to encode a Xvid file to H264 so the picture is HD quality, or as close as I can get to HD. I have tried various programs like SUPER and MeGUI. I don't know much about MeGUI, so I can't seem to make the picture any better. It actually seems to get worst. I don't know much about the bitrate and stuff like that. I have some experience, but not much. I have read a lot of guides on how to do this, but most are for encoding DVD to H264/Blu-Ray. My file is an AVI file with Xvid codec. Any tips or help would be much appreciated.
Thank you
You can't take a lower quality XviD and make it high quality H264. You need the original DVD to start with but even then, you don't get high definition. You would need a Bluray disc to start with.
Thank you for your response. Do you know of any way I can improve the quality of the picture for this file. It doesn't have to be HD.
Basically the 2nd Law of Thermodynamics - everything decays.... you can't improve on what is there, you could explore virtualdub and some of the plugins to sharpen or even noise reduction but it's not going to be better than the original. You should always start off with the highest quality and then compress to the desired size/acceptance of loss of quality. Basically you can't have it all!
cutting h264 video without re-encoding
By dhawald3 in forum EditingReplies: 30Last Post: 18th Nov 2014, 16:46 -
The best simple H264 Encoding App ?????
By Arlo in forum DVD RippingReplies: 3Last Post: 10th Dec 2008, 14:18 -
h264 encoding
By aeroliteflyer in forum DVD RippingReplies: 2Last Post: 22nd Mar 2008, 08:12 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20 -
Questions about CCE, H264 and AviSynth
By Maikeru-sama in forum Video ConversionReplies: 18Last Post: 21st Dec 2007, 20:38
