Hey, all guys, long time no see, i am considering to buy a new hard drive insead of my old one, i searched the internet, went to the amazon,newegg,e-bay, and so on.And at last this one --2TB Hitachi Internal 7200RPM Serial ATA Desktop Hard Drive caught into my eyes, it is 2TB, and second its price,not high.I know a little about this brand, what do you think about it ? Hope you can tell me some details about it.
Any input apprciated, thanks!![]()
Get a Samsung F3 Spinpoint 2T hard drive which is much better than a Hitachi.
Just my 2 cents!
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152202 -
Hitachi took over the IBM line of drives in 2002. The IBM deskstar drives then used to be known widely as 'deathstars' for their high failure rates. But Hitachi seems to be making more dependable drives these days. I've used a couple in the past few years with no problems, but I would also recommend the Samsung drives over the Hitachi drives.
If you don't mind a bit of reduced speed and some power savings, the WD 'Green' drives are also an option for a large HDD. -
For me, the only thing that Hitachi has going is the price for the 2 tb hard drives. I bought one in the past but had 2 exchanges and a return finally because coincidentally they all had something loose when I shook them. And the drives were pretty loud when running.
As for Samsung, I bought a spinpoint f3 1 tb and the progress bar, during file transfer, freezes time to time after a few weeks of use.
I'd personally go with WD caviar blacks (haven't tried out a green), a bit on the pricey side but haven't had any problems with them.
But if I had to choose between Hitachi and Samsung I'd go with Samsung. -
I prefer the WD Caviar Black myself. If you're patient, NewEgg has specials on them from time to time. You might wait a good while if you're set on a specific size though.
I might mention that budz and redwudz have a good deal of experience with this.Pull! Bang! Darn!
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
