Hello folks,this is my first posting on here and I do have a problem with my Panasonic DVD recorder.The model is DMREZ28.My problem is that I've noticed that the picture looks a slight bit BIGGER than it should. When I watch the TV without the unit plugged up I can see the difference. I'm using the input select 2,because when I use input select 1, the picture has dark bands of color in it. Ok,this is actually two problems. This is very annoying because I can't use the unit to record anything with the picture larger,and cut off at the top and bottom.Any help with this would be most appreciated.![]()
Hi, thanks.I also have model numbers Panasonic DMR E 30, E50, and E55.I'm using the same TV for those models also,but the problem does not happen when I use these machines. The problem has to be with the Panasonic DMREZ28 model.
I have a HD DVR and TV hooked up to a Panasonic DVD burner
By tcory in forum DVB / IPTVReplies: 1Last Post: 7th Jan 2011, 20:53 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 06:10 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 19:43 -
what screen size for video in phone???
By askformore in forum Portable VideoReplies: 1Last Post: 6th May 2007, 20:24
