Hi, I have just installed ffmpegX on my iMac with Snow Leopard running unfortunately when I try to convert an AVI file the resulting file is 0k and, obviously, doesn't work.
I am trying to create a FLV the AVI file is called Case 1.avi the resulting 0k file is called Case 1.avi.ff.flv and I've tried to create an MPG and it's called Case 1.avi.ff.flv.mov - but it's 0k - (that's zero K, by the way, not OK!)
Please post the Process Information log for a failed conversion. You may access that log by clicking the blue "i" in the Progress window after a conversion attempt (e.g to FLV).
This log should hold information and error messages that should help diagnose, and find a way to get a good conversion.
I actually got Prism to do it after all.
Here is the info log for the conversion that results in a zero k file. Thanks.
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Thu May 20 21:21:10 BST 2010
Input #0, avi, from '/My stuff/Work/Clients/IGDP/Web/movies/Case 5.avi':
Duration: 00:00:02.2, start: 0.000000, bitrate: 983 kb/s
Stream #0.0, 4.00 fps(r): Video: cinepak, yuv420p, 800x600
Number of stream maps must match number of output streams
I've been using this for years on my G5 and love it. Now I'm installing FFMPEGX on my new iMac and can't get it to convert, well, anything. Mostly to FLV. It's a QT recorded movie I want to make flash video. MOV to FLV, although nothing seems to work. Here's my process file:
Thank you.
Fri May 21 16:59:03 EDT 2010
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Seems that stream 1 comes from film source: 120.00 (30000/250) -> 24.00 (24/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/iMac/Movies/Movie Recording 5.mov':
Duration: 00:01:26.1, start: 0.000000, bitrate: 655 kb/s
Stream #0.0(und): Audio: aac, 44100 Hz, stereo
Stream #0.1(und), 24.00 fps(r): Video: h264, yuv420p, 640x480
Codec type mismatch for mapping #0.0 -> #0.0
Merge two FLV files
By goheadtry in forum Newbie / General discussionsReplies: 19Last Post: 16th Dec 2010, 21:34 -
Certain FLV Files can't be Converted ?
By cheng in forum Video ConversionReplies: 7Last Post: 23rd Feb 2009, 22:27 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 15:11 -
Converting .flv files
By gino_76ph in forum Video ConversionReplies: 8Last Post: 28th Mar 2008, 21:06 -
Joining FLV files together
By DRP in forum EditingReplies: 8Last Post: 27th Oct 2007, 20:07
