i have got a 1 gb mp3 player. recently while adding songs in the player, i accidently deleted all the files, songs from it. now i am unable to any play songs on it. most probably i have deleted everything from it including mp3 player & system files. please help in restoring my system.
Check the manufacturers website, there may be some kind of restore utility available.
I have had a bunch of those inexpensive mp3 players, and all the ones I have had have the player software in firmware. I am thinking that the player only knows where to find the music inside one location. Typically the mp3s are placed into a folder labeled MUSIC or MEDIA on the root of the drive. You may want to see if that is he case for yours.
You may also be able to find some info/help at http://forum.s1mp3.org/
Good luck!
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 04:12 -
Encoding Mp3's for use in Flash player
By JohnX in forum ffmpegX general discussionReplies: 1Last Post: 26th Oct 2009, 14:20 -
Is there a player that will PLAY dvd folder from a flash drive?
By silver007 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Oct 2009, 16:03 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Did I install the wrong mp3 codec?
By Havoc X in forum Software PlayingReplies: 3Last Post: 2nd Jun 2008, 22:22
