I have burned 100 CDs containing my product brochure 2010 in multisession mode i.e. the CDs are open for further writing. The reason is that i may or may not require to distribute this last lot of 100 CD brochures this year. The data space used is only 200 MB. My thinking is that if not used this year i can ide the present 2010 data and burn another 200 Mb of 2100 data (i.e. my next years catalogue data).
My questions are:
01. If i need to distribute the multisesion CDs of 2010 the way thy are right now (multisession open) would they be playable (autorun and all) on my potential customer's PC or do i have to compulsorily finalize them?
02. If i need to finalize the Cds necessarily, which software can do this . I use power2Go to urn the CDs. However I cannot find how to finalize them. What i have to do is add a harmless file (such as a blank text file) as additional data and then the burn now button appears ready for use. Is there a way to finalize without the addiional data being pretentiously added? Is there software that only finalizes? Lastly, can my discs be fialized on another buner and another program?
I think a mod would care to have a word with you for bumping your post in this way.
Now, to answer, IIRC the act of putting any more data on to a CD closes the previous session which normally makes the old data inaccessable. You can use some tools to access the old data but your typicial user will not be able to do this.
Need to Compile Two Recorded Disks And Add A Menu
By Frank-0-Video in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2012, 06:39 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
Players that support multisession rewritable disks?
By rvman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Mar 2008, 10:30 -
Can only read the first session in a MultiSession recorded DVD?
By demf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Sep 2007, 12:16 -
Daewoo Adapt Function for using disks recorded on other Machines
By bullfrog in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th May 2007, 18:16
