Hey, I'm asking for help, again. I don't explain myself well, so bear with me. What I'm trying to do is: I have avi, or mkv files that I want to convert to dvd, and I use DVDFlick to do it. But the end result will be too big to fit on a standard 4.7gb dvd, So I want to set the target size to 8.5gb (dual layer). just doing the conversion and setting the output to the hard drive, so just ending up with the "AUDIO_TS" and"VIDEO_TS" folders and their contents. Now if I open "imgburn", use the build feature, and follow the instructions on how to burn dual layer discs, there is no information for the program to gather from which to create the layer breaks, so how do I create them? Thanks.
Nonsense. Maybe if you set the size to 4.3GB like you're supposed to do, it'll come out the right size - to fit on a single layer DVD+/-R. No downloaded AVI is worth a dual layer DVD:
http://www.digital-digest.com/articles/AVI_to_DVD_using_DVD_Flick_page1.html
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
