I want to use MEncoder for encoding my video files to watch them on mobile
This should be the output of MediaInfo for my video:
General
Format : MPEG-4
Format profile : Base Media / Version 2 [even isom would do]
Codec ID : mp42
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : 20
Bit rate mode : Variable //Note: I want to use the option vqscale=4
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Bit rate : 112 Kbps
Maximum bit rate : 239 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Currently I used this cmdline
mencoder.exe "Inputvideo" -sub "InputSubtitles" -subfont "c:\WINDOWS\Fonts\arial.ttf" -subfont-text-scale 3 -of lavf -lavfopts format=mp4 -oac lavc -channels 2 -ovc lavc -lavcopts vcodec=mpeg4:mbd=2:trell:v4mv:turbo:vqscale=4:acod ec=libfaac:abitrate=112 -ofps 24000/1001 -af resample=44100 -vf scale=640:360 -o "Outputfilename.mp4"
but I couldn't hear the audio though MediaInfo/MediaPlayerClassic detected the audio file.
I went through the entire documentation of MPlayer (eagle's view) but couldn't find my solution... so pls help...
Results 1 to 1 of 1
how to stream live tv on mobile
By funzclub in forum Video Streaming DownloadingReplies: 4Last Post: 26th Mar 2012, 12:01 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 06:14 -
Should I Get T-Mobile Or O2 Contract?
By Nitro89 in forum Off topicReplies: 0Last Post: 18th Jul 2009, 14:03 -
audio from mobile
By devdev in forum AudioReplies: 1Last Post: 14th Apr 2009, 17:10 -
MP4 on WiMP Mobile?
By Memo_182 in forum Portable VideoReplies: 3Last Post: 7th May 2007, 15:34
