VOB2MPG - VIDEO_TS AND VTS_01_0 aspect ratio problem:
Video_TS is in 4:3 aspect ratio
VTS_01_0 is in 16:9 aspect ratio
When I play the DVD, it comes out looking 16:9 properly, even on the VOB2MPG preview it is 16:9, but when I use VOB2MPG to extract, it comes out looking 4:3 argh!
This is the only DVD I ran into that does this.
Any ideas on how I can extract it so when it plays it's 16:9?
doesn't look like a real dvd. it wouldn't have a ntsc menu and pal movie. try to get a legal copy.
There is aspect info in the video as well as the IFO. Try DVDPatcher.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Interesting. An ntsc menu and pal movie. How can that be possible even though it's a DVDR? Why would specs from the menu be transfered to MPG?
I will try this DVDPatcher.
Thank you for your replies.
Edit:
Used DVDPatcher on it and it did change the Aspect Ration from 4:3 to 16:9. However, the indesing got all out of whack, it doesn't seek properly, you fast forward to the middle and it still displays the beginning of the video.Last edited by Joey9; 20th May 2010 at 15:21.
For anyone else who might come across this problem, after trying dozens of different video tools, I solved it in combination with DVDPatcher 1.06 recommended above by Jikchung.
To fix the indexing problem after DVDPatcher is applied, use TMPGEnc Xpress 4.7.4.299 MPEG Tools to demux the whole thing.
Then use TsRemux 0.21.20.23.2 hobBIT to remux. This fixes the seek problem.
Aspect ratio fixed, MPEG seeks perfectly, problem solved.
Hopes this helps others who come by this problem.Last edited by Joey9; 20th May 2010 at 20:53. Reason: Solved
Have you tried patching the first header only in dvd patcher? Perhaps that doesn't muck up the indexing?
Vob2Mpg Pro problem with extracted MPG aspect ratio
By Spoon_Lover in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Oct 2010, 04:20 -
Aspect Ratio Changes from 16:9 to 4:3 after VOB2MPG extraction
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 19th May 2010, 13:24 -
Toast 9 Video_TS burning + aspect ratio
By brumos in forum MacReplies: 1Last Post: 29th Jul 2008, 08:34 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47 -
VIDEO_TS (852x480) -> MPEG conversion: Aspect Ratio?
By jswayze in forum ffmpegX general discussionReplies: 7Last Post: 10th Jun 2007, 10:12
