Hi.
I recently sent off a DVD which I have authored which features 19 short music videos, 2 audio streams: stereo music in the english language stream and 5.1 in the spanish audio stream. I have burned many quality control copies of the disc which have worked the way i have wanted them to aside from some occasional aspect ratio issues because it is a 16x9 DVD but features a few vertically letterboxed 4:3 videos as well. Anyway, the disc has played fine according to my quality standards on all my testing.
Today I received an email from the DVD replication company that the disc I sent them is bad with the following error report (which reads like Greek to me):
"Descriptor location and Tag location field disagree
A Descriptor's address does not agree with the actual location where the Descriptor was found.
Since this error can occur with various Descriptor types, the EclipseSuite programs will display one of the following messages in the Additional Info column of the Analysis identifying the descriptor in question.
ECMA167: Location [x], Tag location field: [y]
ECMA167: LVID Sequence Location:[x], Tag location field: [y]
Type: UDF 2.50
Reference: UDF 2.2.1
Default program Action: Error
Rule ID: 707"
I had not expected any problems and now I have a problem which I don't even understand, much less how to fix. Is there anyone out there that has any idea what this could possibly be related to. Or at least some advice as to what I should start looking into?
Any advice or suggestions would be more than greatly appreciated since we have already started promoting the DVD a bit. Thanks in advance. Sincerely, Polyphasic.
Make a request for confirmation they are using the current updated version of "EclipseSuite"
There are inconsistencies between media / burners descriptors which may trigger such errors when this suite cannot find a method around reported issues.
And this link gives a general overview of UDF.
When you speak of not having issues previously is this the first time you have used their services ?
Down below on the site you'll find "Assumptions for UDF Reader" and a link to the udf verify utility which is what one should use before sending copies to be produced. -
ok. i will definately ask them about whether their eclipsesuite is updated.
i can see that there would be inconsistencies with media/burner descriptions because even the dvd behaves somewhat differently between players from time to time.
yes, this is the first time i have used them, but they are a very large and professional company and been very friendly and helpful so far. i just found out about this problem today and am trying to fix it. i have asked for more information from them and i hope that they will provide me with some guidance but I am not counting on it. -
Hi all,
I have the same problem. Is there any more information, advice or fix ?
By the way, the plant uses version 5.2 of Eclipse. And the UDF version of the DVD is 1.02. You can check out the full report in PDF here : http://poubellelqt.free.fr/temp/
Thank you.Last edited by Lucius Snow; 23rd Jun 2010 at 13:23.
Hard disk report (Windows CHKDSK)... conclusion?
By PartingShot in forum ComputerReplies: 7Last Post: 12th Mar 2010, 13:48 -
master dvd
By butterflies in forum Authoring (DVD)Replies: 6Last Post: 3rd Feb 2010, 01:51 -
Question about using external hard drive with USB DVD player
By jimdagys in forum ComputerReplies: 2Last Post: 29th Jul 2009, 18:49 -
Saving dvd recorder hard disk videos says error
By xmanhattan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 14th May 2009, 12:16 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 08:57
