I trying to figure out a easy way to put my mkv 1080 p on dvd-dl to fit on the disc to play in my ps3 and blu ray standalone player. i know all 1080p movies wont fit on one disc i been trying alot of programs i just cant find the right one can someone please help me.
multiavchd having some problems using this program do they have any easy guide for mkv to avchd for blu ray\ps3
Haven't seen one. What is the problem you are having ?
Basic guide.
1. Open Multi-AVCHD and click Add File
2. If the file name is green in the list, go to step 4
3. Click on the filename to open properties page, then click on Transcode. Choose Two Pass Fast for encoding and enter correct bitrate (use a bitrate calculator)
4. Set you menu options and subtitle options if appropriate. default subtitle settings are usually fine unless you want to force the subs on.
5. Check your output destination (bottom of the screen)
6. Click Start, then chose AVCHD Relaxed and wait until it is done. Could take several hours.
Once it completes, burn the results with Imgburn. Select the BDMV folder and Imgburn will set itself up for AVCHD burning automagically.Read my blog here.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 03:07 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 11:53 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 15:58
