I've got hundreds of old titles on VHS tape I'd like to preserve. What's the best "black box" out there on the market now for overriding VHS Macrovision and CopyGuard when transferring to DVD? I'm looking for something to physically put in-line between my VCR and my DVD burner deck.
Check out world-import.com. The CopiAll does a decent job via composite or s-video connection. I have one and am very satisfied with the results.
Personally I would get a TBC if you have that many. Not only will it remove the offending signal errors, but it will help stabilise and sync correct your source while transferring. That said, it might also be cheaper to just by the DVD versions of those that have been released, as you will never get the same quality from VHS source.
Read my blog here.
As someone who has transferred hundreds of VHS tapes to digital, I would definitely agree with guns1inger about using a TBC. An avt-8710 (like I've been using for years) is currently $215 at bhphoto, which is just $60 more than fooledagain paid. For that extra $60 you get a full-on TBC with built-in proc-amp which lets you also adjust brightness, contrast, color, tint (NTSC) and sharpness as you're making the transfer. If you've got a big job, it makes life so much easier to have quality tools.
Once you're done with it, you could even sell it (on ebay, for example) and get part of your money back.
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 19:34 -
how does one create a "blocked white" quote box in forum posts?
By PosRole in forum FeedbackReplies: 11Last Post: 24th May 2009, 04:46 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 05:04
