Response in a Q ... to reduce colour bleed was to adjust Chroma noise using Chroma Shift.
The suggestion was to 'zoom' in on a vertical edge on a frame and count pixels, to estimate Hshift needed.
What avi viewer is best used to allow this ? ....... windows media player won't zoom above 200%,
Vegas won't zoom either
Virtual dub won't zoom (or I can't find option if it does)
assume there is a better avi player I should be using ? anyone care to advise
VirtualDub: Right click on one of the panes and select the zoom level -- up to 400 percent. You can also use Windows' Magnifier: Start -> All Programs -> Accessories -> Accessibility -> Magnifier.
Thanks, Jagabo - I wasn't aware of Windows Magnifier.
It's quite neat, but I was dismayed to find it re-arranged all my carefully placed desktop icons.
in Vista it open up a separate 'magnify window' ... but 16x does not give enough to work out pixel offset.
tried right click in VD ... it does bring up an option to zoom .. up to 100% .. but when I select it , nothing changes on screen ..tried in static and in 'play' mode.
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
QUERY: zooming in/out and panning... of screen video capturing
By andwan0 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jul 2010, 05:21 -
Lines in middle of video when panning or zooming in/out
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 11th Jun 2008, 17:31 -
zooming on a screen area
By brushuk in forum EditingReplies: 1Last Post: 29th Apr 2008, 06:17 -
How to stop convertxtodvd from zooming in
By andre477 in forum Video ConversionReplies: 40Last Post: 7th Jun 2007, 09:16
