OK this is my first attempt at doing this so I probably missed something, hopefully someone can point me in the right direction.
I had a mkv file, i used tsmuxer to convert to blu ray using the blu ray button in the program.
I then made an image file using imgburn and burned that image to a DL DVD.
Wouldn't play at all on my Panasonic blu ray player.
On my Toshiba blu ray player i get audio but no video at all.
Not sure what other info you might need to help me figure this out.
Any guidance would be deeply appreciated.
	Is the mkv blu-ray/avchd compliant ? See https://www.videohelp.com/hd#tech and use mediainfo to get all info from the mkv.
 And try use multiavchd and avchdcoder instead of tsmuxer.
  issues playing burned DVD's on sony blu ray player bdp-s300By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12
  Only getting L and R audio from PS3 (burned DVD and blu ray)By tikigod19 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 4th Feb 2011, 09:03
  Blu-ray player in computer versus standalone in terms of qualityBy canadianjameson in forum DVD & Blu-ray PlayersReplies: 10Last Post: 29th Jun 2009, 16:53
  HDDVD to Blu-ray playable on standalone BR playerBy miko611 in forum Blu-ray RippingReplies: 1Last Post: 30th Apr 2008, 08:26
  how to burn and play the MTS files on standalone blu ray player using BD RBy ticos2000 in forum Authoring (DVD)Replies: 12Last Post: 28th Jan 2008, 20:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
