Hi all,
I am digitizing vhs tapes using my DVL915U camcorder from JVC. My Proc Amp (studio 1) and VCR (HS-HD2000U) are connected via s-video, but the last link, from the proc-amp to the camcorder is a composite cable (red/white/yellow plug). I would very much like to use a s-video cable for that as well.
Is there an s-video input cable available for this camcorder?
Thanks for taking the time to read this.
The manual shows only composite input.
http://www.kiva.org/about -
I don't exactly know that JVC model but nornally the same analog output connection/cable will also function as input depending on the operation mode of the camcorder.
Ofcourse you then also need to connect the sound (red/white) but not the composite (yellow) connection.
This is how it works with my Sony D8 camcorder so i guess it should work the same with the JVC's analog inputs. -
Yes, the JVC works the same. A standard s-video cable is all you need.
Life is better when you focus on the signals instead of the noise.
Need mic input on camcorder
By loldmanjenkins in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Dec 2010, 17:00 -
Will this work? cable tv w/o STB split to HDTV and VCR with input via AV
By rcholden in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 17:19 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
Trouble capturing video from my JVC GR-DA30 camcorder.
By Baby Mike in forum Capturing and VCRReplies: 1Last Post: 27th Dec 2007, 17:33 -
Burn'n DVD video JVC GR-D72 camcorder (((HELP)))
By sm head in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2007, 17:55
