This problem just turned up yesterday. I have some files that I downloaded. To make one complete movie I joined the two parts using VIrualDub. The only problem I encountered there was that VDub detected that the audio portion of the files was VBR, so it automatically adjusted itself for that. When I burned the combined file, using Convertx, I noticed that the video preview was showing a split screen with the same image in each half of the screen. And, this also appears to have happened when I copied what I at lest thought was a good conversion of the combined file, also using Convertx.
I've checked my settings on Convertx, and, don't see anything, obvious to me, as to why this is happening.
Any and all help on figuring this out, is appreciated.
BTW Baldric;
if you answer this, I started to try avidemuth, but couldn't see in your guide on what to do to have the program start the conversion process, and, wasn't sure if it would burn the result to DVD automatically, if at all. If you could clear that up, it would be appreciated.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
PowerISO and ConvertX
By Aristocles in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2009, 22:45 -
Double image!!
By Cabal2000 in forum Authoring (Blu-ray)Replies: 11Last Post: 5th Feb 2009, 13:00 -
Serious ConvertX Problem
By Kupo in forum Video ConversionReplies: 9Last Post: 12th Jul 2008, 10:22 -
convertx to dvd
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 13:54
