I need to read an EDL and process it by a piece of software. Anyone an idea where I can find a specification of an EDL?
Have you tried opening one in notepad ?
Or perhaps tried google ?
A quick google for "edit decision list format" came up with these, amongst many others
http://en.wikipedia.org/wiki/Edit_decision_list
http://www.edlmax.com/index.htm
http://broadcastengineering.com/newsrooms/broadcasting_aaf_superedl/
http://en.wikipedia.org/wiki/Comparison_of_video_editing_software#Output_options
Vegas can save either an EDL as a plain text file, or an AAF format, which is not plain text readable. I have attached samples of both from the same edit.
The bigger question is how portable these EDLs are between editors, which will tell you a lot about how standardised the EDL format is.Last edited by guns1inger; 19th May 2010 at 04:28. Reason: Added sample files and extra links
Read my blog here.
Yes I opened one and it doesn't look very complicated. Nevertheless I have to know which field represents what information.
The links provided by google don't provide any usable infos. -
Oh.. Was this upload here before my reply? Didn't see it
Well that brings me to the next problem. The Sample EDL I was provided looks completely different (see attachment).
I was thinking that the .eld file format was standardized... -
The original EDL was for analogue systems - film and tape - and even when it was originally computerised, it was still only a record of the edits, not an automated process. Digital EDLs for NLEs seem to be program specific, and even though they follow a similar basic pattern - clip names, start frames, durations etc. - there appears not to be a standard that all follow. I suspect that there will be a key set of fields that are common, be each adds whatever else they want to for their own functionality, thereby extending it. Perhaps you could ask for samples from several different NLEs, look at the formats for each, and create import filters for each one that reads the EDL and strips out the basic core information. I don't know what your assignment is specifically, or how this fits into it.
The AAF format is an attempt to standardise EDLs for digital editing, and I suspect that most of the major NLEs will read and write the format. If you look at the member organisations for the association behind the format, you will find most of the major players (although not Apple, unsurprisingly). Given it's proprietary nature, you probably have to license the format for use, and membership is the simple way doing this.Read my blog here.
Which file format to use
By drtanz in forum Video ConversionReplies: 2Last Post: 16th Oct 2011, 14:46 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
