I was wondering what was the best bluray to avi/xvid converter (that works), i prefer my files as avi so i can watch them from my docking station, i have tried handbrake 0.9.3 but the output had audio problems (think it was the program) and the newer version doesn't have the avi capability.
Any help here would be appreciated, if there isn't any decent ones i will continue to use makemkv for the time being but whenever i use that and forward the film i get green squares when i play the file they are not there all the time but it is annoying.
Thanks in advance
I can't see why you would want to go down the AVI route, as the compression available is far lower than the source, you get either bigger files with the same quality, or much lower quality.
You haven't posted your computer specs or what software player you use, so we can't try to solve your playback issues either.
However if you must convert, you could look at Xvid4PSP as one possible option.Read my blog here.
Right resizer from BluRay to Xvid-Avi
By split710 in forum Blu-ray RippingReplies: 0Last Post: 23rd Jun 2011, 03:02 -
Which PC bluray recorder for Christmas? What features are important?
By innovator in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Nov 2010, 02:13 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
whats the fastest video converter?
By ADDlCTlON in forum Video ConversionReplies: 4Last Post: 10th Mar 2010, 16:29 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36
