hi every one,i know that DTS audio causes a lot of confusion in converting video to DVD so it came to my mind to build the DVD with no audio then add the dts audio and complete the process,i really enjoy dts audio unlike ac3 so at any cost i will not sacrifice dts streams,recently i'm using convertxdvd and every thing is fine but,after using TMPGEnc and AVStoDVD i found that both tools are more powerful than convertxdvd in video encoding .unfortunately they both don't support dts format ,so i decided to separate audio and video streams from the source file then encode the resulting video file in AVStoDVD and build a DVD folder with no audio,afterwards i tried to add the dts audio to that DVD folder before burning , the question is: is that possible or there is another way?if it is, how can i add that dts stream to VOB?i found that IfoEdit can do it but it has no user friendly interface and i can't use it, convertxdvd does the job pretty well (convert,encode,author and burn) in one click,but the resulting video not that good as AVStoDVD which made me change to it but still the main problem the dts audio.another thing ,is there any software like convertxdvd (does every thing in one click )but has more powerful video encoder and supports dts than convertx does.thank you all in advance
Results 1 to 30 of 57
Take the M2V video and the DTS audio and author them to DVD using Muxman. If you only have whatever DVD you made, demux the video using PGCDemux. If you only have VOB(s), open it (them) in DGIndex and go File->Save Project and Demux Video. Then author using Muxman. If the source of the DTS audio is a Blu-Ray, then most likely it won't work for DVD.
Then it's not DVD compliant. Like I said before, if the original source for the DTS track was a Blu-Ray, then the chances are very good it's not compliant for DVD. I don't use ConvertX2DVD and can't speak to why it's accepted there.
so there is no way adding dts stream if it's not dvd specification, still wonder how convertx can handle dts streams even if they not dvd compatible (1.5 mb/s,48khz sample rate with 24 bit resolution)
There must be something wrong with it, but DTS for DVD-Video is allowed to be 24 bit:
http://www.dvddemystified.com/dvdfaq.html#3.6.2DTS (Digital Theater Systems) Digital Surround is an optional multi-channel digital audio format, using lossy compression from PCM at 48 kHz at up to 24 bits.
http://en.wikipedia.org/wiki/DTS_%28sound_system%29#DTS_96.2F24DTS 96/24 allows the delivery of 5.1 channels of 24-bit, 96 kHz audio and high quality video on the DVD-Video format. -
Are you saying that Muxman won't accept 24 bit DTS audio as input? I don't know as I don't have any with which to test. He doesn't say much on his page about supported input:
http://www.mpucoder.com/Muxman/versions.shtmlDTS - 48K sampling rate, 768Kbps or 1536Kbps, 5.1 channels.
If you're right, then yes, this should be brought to his attention.
Chapters are created when authoring, not later. IFOEdit and Muxman accept them in frame number format in a text file. For example, if you're PAL and every 5 minutes is OK, then:
7500
15000
22500
30000
If you want to set them at specific scene changes, then open it in something that shows frame numbers (an AviSynth script in VDub(Mod)or the M2V in VDubMod). NTSC needs to be for 29.97fps frame numbers.
If you want menus, then use an authoring program that allows you to make menus (for free, DVDAuthorGUI, GUI4DVDAuthor, DVD Styler).Last edited by manono; 20th May 2010 at 21:04.
does dvd authoring programs do any change to the quality or th the video bitrate of the m2v files ?
Good authoring programs do not re-encode or transcode, so they do not affect the visual quality of the source. Ditto with audio. Some of the consumer authoring tools will re-encode, often without telling you (think Nero/Roxio and other toys). If you use something like IFOEdit or Muxman then there will be no re-encoding. Same for higher end tools like DVD Lab Pro, DVD Workshop etc.
Read my blog here.
No change in either video or audio...your affectively putting both streams in a suitable carrier for DVD work.
Try the demo version of DVD Lab Pro. It can author DTS audio. If it doesn't accept the audio or can't mux it, then the problem lies with your audio file.
Read my blog here.
yeah i know dvd lab pro !!! what a tricky one , i got lost wondering through it's menus could any one help me with it please! just in muxing m2v with dts
can any one help me in authoring dvd with dvd lab pro ?just simple steps please how to make chapters and menus?
This covers the basics : http://www.digital-digest.com/articles/DVD-lab_Pro_Basic_DVD_Authoring_Guide_page1.html
Read my blog here.
DTS audio stream not recognized in m2ts playback w/ PowerDVD or PVRX2
By bigshotceo in forum Software PlayingReplies: 0Last Post: 9th Feb 2010, 09:45 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42 -
Clicks in DTS audio stream in MKV file
By MisterB42 in forum AudioReplies: 0Last Post: 23rd Aug 2007, 17:25
