I know this can be done (I've seen discs with different aspect ratios for different segments), but when I try to do this (with something like TMPGEnc4), the 4:3 get blown out to 16:9 ratios. I would like to use transitions between the segments, but this is not mandatory.
Thanks!![]()
They must be in separate VTS titles or I guess it's called tracks in tmpgenc authoring works.
And if you insist on them being part of the same title, so you can use your transitions, you'll have to convert the 4:3 video to 16:9 by resizing and adding pillar bars.
Mixing AVCHD with SD DV-AVI, frame size & arrangement question...
By sdsumike619 in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2012, 23:18 -
Mixing 4:3 & 16:9 using dvdauthor
By juhani in forum Authoring (DVD)Replies: 12Last Post: 5th Jan 2011, 06:31 -
Copying Segments From DVD`s Advise.
By opopopo in forum EditingReplies: 9Last Post: 9th Jan 2010, 06:41 -
DVD Rebuilder - number of segments?
By ecc in forum Authoring (DVD)Replies: 4Last Post: 11th May 2009, 19:30 -
DVD Rip segments ---> FLV
By statman24 in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 10:14
