I have an MPEG-2 file which was generated by tivodecode (from a file downloaded from my TiVo). It's the kind of MPEG-2 that Quicktime's MPEG-2 support can't deal with. But it plays correctly in VLC -- both video and audio
I dragged it into ffmpegx 0.0.9y, and tried exporting to a number of different formats. I wanted to convert it to DV, but that format -- like the majority of them -- failed; as soon as I clicked "encode," the "done" bell rang, and I had an empty file.
So I tried both h.264 mencoder and h.264 x264. In both cases, the files did encode, but I ended up with two separate files: a video file and an audio file. Okay, I can deal with that. I'll be dragging them into Final Cut Express. But in both cases the separate audio file was empty. Zero K. Any idea how I can get the audio out of this MPEG-2 file?
Here's a screenshot.
Thanks,
DM
Please post the Process Information log for a failed conversion. You may access that log by clicking the blue "i" in the Progress window after a conversion attempt (e.g to DV).
This log should hold information and error messages that should help diagnose and find a way to get a good conversion.
I've been having this same problem, but I'm bringing in an M2TS file. Video comes out fine, audio comes as a separate file (though I'd REALLY prefer to have them together in the same container), but the audio is always empty.
Here's one info log, this one I tried with "invert mapping" checked on.
After that I tried one without "invert mapping", and here was the log (note these are separate but similar m2ts streams, both recorded back to back):Duration: 00:02:35.2, start: 0.437089, bitrate: 8121 kb/s
Stream #1.0[0x1011], 59.94 fps(r): Video: h264, yuv420p, 1280x720
Stream #1.1[0x1100]: Audio: ac3
Codec type mismatch for mapping #1.0 -> #0.0
I also want to note from that previous one that the audio file isn't 0KB, it's 4KB. When I set invert mapping on, it came out 0. In both cases, the video file works fine. I've tried selecting the track from zero to 3, but have had no success.Stream #0.0: Audio: aac, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #1.1 -> #0.0 [sync #0.0]
Press [q] to stop encoding
video:0kB audio:0kB global headers:0kB muxing overhead 7900.000000%
Several tracks in MP4 - please indicate track to import
Error importing filename.audio.mp4: Bad Parameter
The audio would have been muxed with the video, if the audio conversion succeeded.
Apparently, the AC3 in an M2TS file is too confusing for the ffmpeg version inside ffmpegX 0.0.9y. Notice how it detects ac3 audio, but can't give any parameters. I'm afraid you'll need something more recently updated to handle M2TS files.
Problems converting H.264 AVC to MPEG2
By Gwar in forum Video ConversionReplies: 8Last Post: 4th Jul 2011, 12:29 -
mencoder x264 vs libavcodec for h.264 encoding
By chconnor in forum Video ConversionReplies: 0Last Post: 2nd Mar 2011, 16:31 -
MPEG2 to H.264 (or x.264) FLV- how to do that?
By spycam in forum Video ConversionReplies: 9Last Post: 11th May 2010, 11:20 -
Slowing down PAL H.264/X.264 files
By ID3_Freak in forum Software PlayingReplies: 6Last Post: 8th Apr 2008, 18:39 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
