Under the prompt, Common Languages Runtime Debugging Services, is the following:
"Application has generated an exception that could not be handled.
Process id=0x80 (128), Thread id=0xe8 (232)."
Does anyone know of a fix for the problem?
Most likely you are missing a file. You would have to know what program caused the error. This may not be simple.
You can do a Google search for ' Application has generated an exception that could not be handled ' and get some ideas from that. Windows has some diagnostic programs that may help you, such as Dependency Walker. http://www.dependencywalker.com/
If you just started to get the error, did you install anything recently that may have damaged or added a file related to this? Have you tried a restore to a point before the problem started?
And welcome to our forums.
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Debugging coaster problem
By txporter in forum MediaReplies: 21Last Post: 29th Apr 2009, 06:43 -
Need timecode display movie for debugging
By cybertheque in forum Capturing and VCRReplies: 6Last Post: 23rd Oct 2008, 17:19 -
ffmpeg works only when debugging
By ariefimansantoso in forum ProgrammingReplies: 0Last Post: 21st Sep 2007, 08:05 -
Common Language Runtime error
By scrtagt69 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd Jul 2007, 03:42
