    Mar 2007
    Pakistan
    Hello,
    Have downloaded the latest version of SUPER converter from their website which is supposed to be 100% Windows 7 Compatible as stated.
    However even since an earlier version of SUPER when I was running it on Windows XP I always encounter the following strange dialog box when starting the program. My computer time and date are set correctly but somehow this screen always appear, and then programs start finally.
    And when I try to exit the program, it shows the following dialog box, and I keep cilcking OK, but the program never exits, and finally I have to kill it from the task manager.
    So ultimately SUPER is a useless pieces of software for me, even though I want to use it.
    Anyone out there with a similar problem and can help me out with it. I have tried running with administrator privileges too but all in vain.
    Thanks.
    I would go to http://www.erightsoft.com/Supforum.html and http://www.erightsoft.com/contact.html and report about the issue.
    Or use other good all-in-one converters like xmedia recode!
