Could be converted an AC3 5.1 file to DTS 5.1 ???
My question may sound stupid but I'm not good at sound at all...
thanks !
It doesn't make much sense to transcode an AC3 file to a DTS file.
There's no quality gain. It's like taking a thumbnail of a picture then enlarging it.
But, are you're looking to transcode the file for better playback compatibility on other devices?
If you really want to transcode the file, you can try eac3to, it looks like can work with AC3 files and DTS files.
It should be able to convert your 5.1 AC3 into a 5.1 DTS. (I haven't really tried it, I use other programs that require much more work and it takes longer.)
eac3to is freeare so that should make things easier to find. check it out...
tools > audio-encoders > eac3to -
DTS is not free, Surcode DTS works with eac3to:
http://www.minnetonkaaudio.com/index.php?option=com_content&view=article&id=54&Itemid=87&lang=en
249.00$
DTS to AC3 5.1
By daemon22 in forum AudioReplies: 85Last Post: 22nd Sep 2013, 00:55 -
Ac3 is indicated instead of dts - please help
By Dr Forrester in forum AudioReplies: 4Last Post: 16th Feb 2010, 09:19 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
AC3 to DTS
By Tolis1989 in forum AudioReplies: 2Last Post: 15th Nov 2008, 12:12 -
DTS vs AC3
By Mrsash in forum Newbie / General discussionsReplies: 9Last Post: 29th Jul 2007, 10:16
