I have access to two versions of a video. One is a high definition MKV, and the other is a SD AVI. Assuming I want to convert them to a standard DVD (720x480 29.97fps), which of them would be higher quality? The AVI is PAL. I don't know very much about HD files. For the AVI I intended to use a slightly modified version of this guide: https://forum.videohelp.com/threads/241000-How-to-convert-a-PAL-DVD-to-a-NTSC-DVD-using...GEnc-Plus-2-5x.
You can always lose quality, you cant add back quality once lost.
IMO go from higher res/quality to lower res/quality every time.Corned beef is now made to a higher standard than at any time in history.
Depends how you downscale.
http://www.kiva.org/about -
If you have the correct software and video knowledge, go the HD MKV to DVD rout.
If not, then better use the avi file plus a couple of filters.
Correct resizing is an issue here.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
Best .avi and dvd to .mkv?
By xxnonamexx in forum DVD RippingReplies: 11Last Post: 14th May 2010, 11:42 -
DVD,MKV,AVi cutters
By mayflower in forum EditingReplies: 1Last Post: 23rd Jan 2010, 13:13 -
convert mkv to avi or dvd
By robotica71 in forum Video ConversionReplies: 21Last Post: 22nd Jan 2010, 08:12
