hello every one i need some people to test my new encode it format
i got some great clip to test on my ftp server please e-mail for info
Results 1 to 13 of 13
is call MPG-DX cause it encode it on mpg but it look like divx some time better than divx and file size is very small over 2hr movie only 694 mb
details, man! details!
How is it encoded? What bitrates? Is your last name "Magoo"?
I'll take a look at this... but it might also help to tell us how it was done (program/settings/bitrate/source)... -
i just hope the divx isnt a bad source quality-- crap in, crap out
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one. -
ok, I tried the clips...
Basically looks like MPEG-1 VBR in the 500K average range...
What's new about the format, though? What program did you use for this?
I do have to say that 1: These are not the most challenging clips in the world, but 2: they look fairly decent for the bitrate they're set at. Product looks like a Panasonic encoder plugin VCD. (do I have that right, I know it starts with P)?
Details, please! -
i used only TMPGEnc bitrate only 1000 quality only 23 and still get good quality
+ the good thing about my encodeing is that movie size never go more than 700 mb most movie i encode i get down to 657 if the are under 2hr
can you write the steps you took and the setting in all the programs you used?
What VERSION of TMPGEnc? Was it a newer version?
I can tell you, that was NOT an older version, I still got blocky product on all moves at 1000+ for an AVERAGE bitrate...
Settings and version # would be helpful (this is like pulling teeth)! -
Beauty lays in the eye of the beholder... I don't think that a bitrate of 1000 with a CQ setting 23 can produce satisfying results unless the actors of the movie seldom move.
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
"Settings and version # would be helpful (this is like pulling teeth)!"
I have to agree... this is just like all of the other posts... LOOK I CAN FIT 4 HRS ON ONE CD!!!!!!!!!!
Big Ol Bunch of BS
after about 20-25 posts trying to get the REAL answer... you find out its just the same ol sh!t.
but remember... this is just MY opinion...
IgGy
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 06:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 00:46 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15
